Please Help, Rattling Problem
  • 3
Ng931227
Hey everyone, u guys were so helpful with my last question I would really appreciate it if I could get some advise on my new problem, my subs rattle my back hatch on my ford escape really bad, I've put dynamats all over the hatch and they definitely help but it still rattles,I guess my questions is how to I kill the remaining rattle, I think it actually might be the actuator that unlocks the car but I can't put anything on that because then I won't be able to unlock my trunk, like a said any help would be greatly appreciate especially since everyone on here seems to know so much, also is there any way to stop my rear door windows from rattling? Thanks a ton
closed cell foam, expanding foam, weatherstrip foam and more foam!!! works wonders! Also, for the actuator, try to see if you can use electrical tape or something thin with a good cushion for it.
I think you're gonna have to get good with fiberglass or something, or find someone with a 3d laser scanner that can 3d print or mold you some...
7
Is this a blue or blue/white wire from the Kenwood? The ACC wire is red and although that should turn on the amp, it is not the prefered wiring...
The sound deadening is going to be more about preventing vibration from metal surfaces and adding unwanted noise. Does it have the JBL system...
It's called the K.I.S.S. preciniple ("Keep it simple, stupid!")... Takes the guesswork out of parallel/series wiring.
As for which signal to use, I tried all combinations and getting signal from the dash and front & rear doors is the only way the system sounded...
15
Ng931227
Ng931227
Sanford, Fl
Jeffdachef
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
