Please Help! Power Problems: Alternator/Batteries
  • 1
LaidD3athl0rd
Hi there, i am in urgent need of an answer, i have been on the research for ages and cannot find a decent answer. I need to find a method to sufficiently power the system without necessarily replacing the alternator for a high output one.
My situation is, i have a ford falcon 2005, it runs a stock 110amp alternator and my car stereo system will pull about 3000 watt rms capable. i dont mind running extra batteries but when the car is on it draws from the alternator until exceeded.
And its a system for whilst the car is running not off, its not going to pull 3000 watt rms for any longer than a song or so but i want it to be able to do rated power for when i am heavy hitting the bass etc.
a few of the following questions i have are:
- A 110amp alternator puts out est 1500 watts lets say. 400 watts of that, powers the car excluding the stereo for example. If i upgrade to a secondary battery in the boot that puts out 2000 watts should this cover the difference?
so if im correct when the alternator exceeds 110amps it will draw the excess from the batteries and at 3000 watts rms stereo system, between the alternator 1000 watts and the battery 2000 watts, this should be sufficient? not going into consideration of efficiency i will factor in that but the basic principles?
Whats the go? will this work? will my alternator not put out enough? are there better alternatives? Any negatives? head light dimming etc.. anything at all.
Any advice will be greatly appreciated, but please don't push me to get a new alternator just yet as there aren't many that suit my vehicle make.. Australia -_-
Thank you.
I think you're gonna have to get good with fiberglass or something, or find someone with a 3d laser scanner that can 3d print or mold you some...
7
Is this a blue or blue/white wire from the Kenwood? The ACC wire is red and although that should turn on the amp, it is not the prefered wiring...
The sound deadening is going to be more about preventing vibration from metal surfaces and adding unwanted noise. Does it have the JBL system...
It's called the K.I.S.S. preciniple ("Keep it simple, stupid!")... Takes the guesswork out of parallel/series wiring.
954
As for which signal to use, I tried all combinations and getting signal from the dash and front & rear doors is the only way the system sounded...
15
LaidD3athl0rd
LaidD3athl0rd
South Australia
LaidD3athl0rd
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
