**Please Help!!** Officially getting pissed!
who cares? I just ran into an issue that I'm trying to resolve... Ive had many set-ups and never had this problem...
Then you should know a hell of a lot more than you do. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
we can't all be "caraudio veterans" that signed up in 2008 //content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
That's the default title
//content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
Don't Care //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
Just trying to solve a small problem, I'm starting to remember why I stopped coming to this site... Used to be great, but a lot has changed. For those that tried to help, thanks.
I did read that the front/rear pre-outs are 5v while the sw pre-out is only 2v, would this affect anything?
Been here since '04 and you ask this? //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
Search.
Riiigghhtt, everyone on this site is a car audiophile... I haven't had a set-up for over 3 years, its been a while lol..
lawl at this thread / OP
i mean most of your posts must have been a looooong time ago or you post in the wrong sections
I had a JVC that was like 2 years old and there was a button on the front you have to hold down for a few seconds and a menu with subwoofer control would pop up..dont remember what button though..
For those that are bashing the OP, grow up...
We all run into problems, no matter how simple it may seem to someone else. I remember having a similar problem on one of my previous h/u's, and it did end up being that the SW CONTROL WAS OFF. I felt like an idiot, but I couldn't figure out how to get to it.
To the OP, you probably have the same issue, find out where to turn the SW control on within your head unit controls.
Read the manual. Check if SW is set to on on HU.
check xover settings on amp+HU
check coils
if sub was built by TC Sounds, check if the thing is magnetized...
Seeing that it's a mono/sub amp, it should just have a Low pass xover, which would lead me to believe the problem is w/ the HU settings.
The sound deadening is going to be more about preventing vibration from metal surfaces and adding unwanted noise. Does it have the JBL system...
It's called the K.I.S.S. preciniple ("Keep it simple, stupid!")... Takes the guesswork out of parallel/series wiring.
As for which signal to use, I tried all combinations and getting signal from the dash and front & rear doors is the only way the system sounded...
15
swaptrex
Supporting Member
swaptrex
Michigan
taintedplay
