please help me wire this!!!
impedance for subs are dual 4ohms...2 Ohm or 8 Ohm operation per sub (1 ohm, 4 ohm, 16 ohm per pair...Voice Coil(s): Dual
Impedance (per voice coil): 4 ohm....Sensitivity: 93.4 dB
Peak Power Handling: 1000 watts
RMS Power Handling: 500 watts
Frequency Response: 21 - 1000 H
---------- Post added at 10:10 AM ---------- Previous post was at 10:09 AM ----------
Power Specifications - Full Range Channels
RMS Power @ 4 ohms 500 watts x 1 channels
RMS Power @ 2 ohms 900 watts x 1 channels
RMS Power @ 1 ohm Not Stable
Bridged RMS Power Not Bridgeable
Amplifier Specifications
Number of Channels 1 - Mono
Total Peak Power Output 1800 watts
Total RMS Power Output 900 watts
Maximum Input Gauge Size 4 AWG
Minimum Impedance Unbridged 2 ohms
Minimum Impedance Bridged Not Bridgeable
THD at Rated RMS Power 0.5%
Speaker Level Inputs Yes
Preamp Outputs 1 pair
Low-Pass Crossover Frequency 50 - 200 Hz
Subsonic Filter 15 - 25 Hz
Signal-to-Noise Ratio 94 dB
Bass Boost 0 - 18 dB
Bass/Gain Remote No
Fan Cooled Yes
Fuse Rating 30A x 2
CEA-2006 Compliant Yes
thanks but my amp has 2 posatives and neg. and on the diagram it is just giving me one set like i;m supposed to splice into them or somethin
No, you can hook each sub to it's own positive and negative if you want, they are connected internally. It's just for ease of use. Looks like your best choice is to wire each sub to 8 ohms then hook positive and negative of each sub to it's own positive and negative on the amp. You will be sending each sub about half of it's rated power, though. If I were you I'd sell the amp and pick up something that puts out ~1000W at 1 ohm if you want full output from them.
The sound deadening is going to be more about preventing vibration from metal surfaces and adding unwanted noise. Does it have the JBL system...
It's called the K.I.S.S. preciniple ("Keep it simple, stupid!")... Takes the guesswork out of parallel/series wiring.
As for which signal to use, I tried all combinations and getting signal from the dash and front & rear doors is the only way the system sounded...
15
greysondad
greysondad
tennessee
naughtyca
    Jun 1, 2024
    May 31, 2024
