MeMpHiS12 10+ year member
It just wont work ive tried everything all kinds of diff. wiring please tell me what you think any suggestions please.
haha, i was just thinking last night about tellin my wife i can't fix a simple "it's broke"...........so what i'm saying, is that we need more information. what have you tried? is the amp coming on, and not in protect? basically test your equipment. do the subs ohm out on each coil good? is the problem that you just don't have sound? if you don't have one, get a multi-meter and take some ohms and voltage readings......
um...what? This has nothing to do with your post or questions asked to you.Whats up man im blake i live in cabot and was looking for other car enthusiast in central arkansas to maybe start up a club so we could work together on builds and go to comps. together just hit me back and tell me what you think
do you have your remote wire and rca's hooked up?
check to ensure you have a good ground and then double check your power wire. When things are stolen they don't care about your wires...so you may have a blown fuse under the hood in your power wire.
if you have a volt meter test your remote wire. If you don't try jumping your remote wire and power wire. A small remote can be stretched to the point were wires can/will break inside the coating.
just take a small piece of wire and jump from the power wire to the remote wire on the amp. If your power wire and ground are good it should kick on. If it does turn on your stereo, if it does not play then your problem is RCAs, head unit rca output, or your subs.
