badshah2000
KIA Sedona 2006 EX
Radio: Kenwood
Pac Product: SWI-RC
According to Pac-audio website, the KIA Sedona plug is referenced by diagram "Hyundai 24".
Installation notes (App Guide #439 on pac-audio/swi website) say:
Note #110 : "Connect the INTERFACE's White wires to Pin 6 (Blue) of the above connector. Connect pin 18 (Blue/Black) of the radio connector to ground."
A couple of questions regarding this:
1. The first part of above referenced note #110 says to connect interface's white wireS (note plural!) to pin 6 (Blue) of the radio connector. Confusion is that there actually are multiple white wires. There is one white wire initially coming of the Pac's interface harness, which then turns into three white wires--one pure white, and the other two are white with different colored stripes on them. Do I connect all three of these white wires to Pin 6 (Blue) of radio connector, or just the Pure White? In other words, should I also connect the two sriped white wires to the pin 6 (Blue) of radio connector?
2. The second part of note #110 says "Connect pin 18 (Blue/Black) of the radio connector to ground". The problem is the pin 18 on my KIA Sedona original factory wiring harness is *not* Blue/Black. It is Red. I have photos of the factory harness taken from various angles which clearly show that while the pin 6 is Blue (as correctly described in note #110 ), the pin 18 (the cable directly underneeth pin 6 in second row per Hyundai 24 diagram) is RED. It is not Blue/Black as the note #110 says. What should I do?
3. Assuming that the note #110 described number of pin 18 correctoly and made an error in naming it correctly (or, Pac-audio will correct the error and let me know of the correct pin number in factory harness to connect with ground): can I just take one of the black wires from pac harness (in pac's interface harness, the black wire coming out of the harness connector is split into two black wires), and connect to the (pin 18) of factory harness?
![](/proxy.php?image=http%3A%2F%2Fs33.postimg.org%2Fpw11dqzpn%2FHyundai24.jpg&hash=7d009687afdb28ffc7d0bb294104cff9)
![](/proxy.php?image=http%3A%2F%2Fs33.postimg.org%2Fbup1s6w5n%2FIMG_3828.jpg&hash=d565ef1dca7eb839ddd15cb599479eae)
![](/proxy.php?image=http%3A%2F%2Fs33.postimg.org%2Fkbok340uj%2FIMG_3829.jpg&hash=44f2841d516b88671d2d44d9c1ce0952)
![](/proxy.php?image=http%3A%2F%2Fs33.postimg.org%2F62oxl1mbv%2FIMG_3830.jpg&hash=e16a84af1ec8d9de637ea98e7e6bbe40)
Radio: Kenwood
Pac Product: SWI-RC
