Optima Red Top battery in front, can I swap it out for a Kinetik HC-2000?
  • 4
yo0123yo
chicago
Ok so recently I removed my two Kinetik HC-2000's from my trunk which I had powering my two Kicker 12" L7's along with a ZX2500.1. Now the car struggles to start every time especially since it's cold too. I looked at the front Optima Red Top and it had a couple of bulges as well so we know it needs replacing. My buddy can swap it out for me but I know that the Kinetik is made for high performance audio, can I take my Red Top out and replace it with the massive Kinetik HC-2000?
Yes. Stock alternator?
Yes, the alternator is stock. Is that bad if I swap to the Kinetik with a stock alternator? We looked at replacing the stock alternator to a high output alternator but they are just too expensive. Car is a 2005 Chevrolet Equinox if that matters lol. My buddy is a mechanic and a huge car guy so I will have him swap it out tomorrow. Should I also do the "big 3" wiring upgrade to 0 gauge since I am already having my buddy do the battery swap? I will buy 0 gauge wire since we are already going to be swapping out the battery might as well knock out two birds with one stone.
Yea do big 3 with 0 gauge but you dont remove any wires you just add wires.
Awesome! The Kinetik HC-2000 has 1500 cranking amps and the Optima Red Top has 800 cranking amps. After swapping to the Kinetik will I most likely notice a big difference especially since now the car struggles to start especially since it is cold outside as well as easing the dimming when playing the system loud? Thanks!!
Will the hc2000 fit under the hood?
That's what I said at first and it is just a TAD bigger than the holder (length with) thats not a problem you can just cut some plastic away and install more support since it weighs 60 pounds lol
Johnson controls makes Optima batteries now. They also make most of the auto parts store and chain store brands. You will be just as well off...
970
So I don't know what i'm doing but I really like the used H-KO but when i look at the specs it looks like it could overpower the sub if I'm...
19
Some equipment like AMPS comes with it no owner's manual. So the lights blinking on or off has to be taken somewhere else. Search engine. Car...
CAF, Williston Audio Labs(Old School Car Audio) and Jonathan Patrick's Brand X videos when I'm trying to wire an alt into a newer vehicle I...
16
yo0123yo
yo0123yo
chicago
yo0123yo
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
