Ohm Load, 2 ohm or 4 ohm - jl audio m series subwoofer amp - for hot weather use in a boat
  • 2
qwiketz
Hi all,
I have a jl m series 600 watt at 4 ohm amp. I have it running at 4 ohm currently driving one sub. The boat is used at the river where it's commonly 120 degrees. I have it in the cabin which is shaded, but still hot. Are you guys typically running amps with headroom as far as ohms, or are you loading them down on occasion to their lowest ohm load when using them in a hot environment like this? Temps are always above 100 degrees and usually above 110.
I’m in Arizona, and in the summer I don’t have problems. I do the lowest ohms the amp is capable of, but I always like to have lots of headroom on watts. If I need 500 rms, ill get a 750 watt amp to keep the gain lower.
Hell... Run It.. You will be ok @ that Ohm load(2.67). Just dont go below 2ohms and you will be fine. 2ohms is the lowest stability of that...
5
Hello I'm happy to have came across this forum as I'm hoping someone will help with this little bit of confusion I'm having and maybe save me some...
It also lowers the amps efficiency and raises the current draw.
5
462
What is the impedance of each set of terminals,assuming they represent each of the two dual voice coil subs (4 coils total)? How many sets of +/-...
299
Not all chargers are the same and charge and different rates. Any battery will deplete in that type of weather if you do not crank the vehicle for...
10
994
qwiketz
qwiketz
Orange County
SlugButter
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
