Amp for my jbl gx1200 sub
  • 3
Rayher12
CarAudio.com Recruit
i was wondering if anyone could recommend me some amps for my sub. It’s a jbl gx1200 250 watts rms at 4 ohms single voice coil. Someone recommended me a Rockville db11 it does 220 cea rated but 440 rms and I was wondering what you guys think or would recommend? I have about 100 bucks to spend on an amp. Thanks
The rockville is rated 350 at 2 ohms. So at 4 ohms which your subwoofer will be at it will probably put out around half that. It has a 40 amp fuse so I don't think it will put out enough power at 4 ohms. It's always good to have headroom with amplifiers. The Power Acoustik has a 50 amp fuse rating and should do slightly more power.
Okay right now I saw it on Walmart’s website for $97, but at Best Buy the have a keyword for 100. What do you think about this one it gives some headroom
this one is 69 but I wasn’t sure about power acoustik being a good brand but now that you mention it I fell better about it.
Still available. Will offer free shipping to US lower 48 states.
5
178
No need to bypass the amp. Most use an LOC that takes the full amped signal and turns it into a flat RCA level signal. Here is the newest I have...
383
6
480
Rayher12
Rayher12
Fresno, Ca
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
