no power coming to head unit
  • 2
DemonaL
Da MaStAH
468
FL
Installing this head unit everything works except for the constant power... I do a test on the factory harness and nothing? The stock radio only has the dimming lights that will light it up... I checked some fuses and nothing... Any ideas?
Who had that Badazzed Astro Van?? I remember going to Austin seeing that ride. That thing made Earth pavement move about 50 ft before I got close...
12
623
Run the biggest AGM you can under the hood, the parallel runs to one of these - should be everything you need and then some...
5
772
What amplifier(s) are you using? What speakers? Is this your main battery or is it a 2nd battery? If it is a 2nd, how are you wired up? What if...
583
DemonaL
Da MaStAH
DemonaL
FL
bw_audio
