NEW US Amps MD22 - fried within the first 30min...WTF??
  • 2
Trixter
Keepin it Simple
I got a new MD22 from someone on here about about 5-6 years ago. I had an old amp go out so I though I'd hook this one up until I got my new one. (It's pushing my dual 2ohm 15" Brahma 1st gen...it's seeing 2ohm/channel. gain @ 1/3, bass EQ about 1/3, x-over @ 100hz, SSF off) It played fine for about 30min or so and then it cut out. All 3 25a on-board fuses were popped. So I removed the 80a inline fuse, replaced the 3 25a, put the 80a back in, turned on the radio and the amp crackled and popped and smoke started pouring from it. Immediately pulled out the main power and removed the amp from the car. No visible damage on the inside of the amp (except for that 'o $hit' smelling smoke), nothing was warm (by this time) and the 3 25a fuses are still good.
Can someone tell me WTF just happened? This thing is brand new!! (Granted it sat for a good few years but this is the first time it's seen power.)
Hey what's up man, it's been awhile.
I don't see any damage to the caps. but the 'deth smell' is coming from where the pwr/gnd/rmt meet the board and the 8 caps right there.
How I would approach it is install your new amplifier and start using it. Install a voltage gauge and if you see your voltage lowering then add...
4
368
Additinally, no need to reference "max" anything as those specs are useless. Most of know how to look at specs for a given speaker, amp, HU, etc...
515
Hello all. Used to come on these forum quite a bit. I used to compete in IASCA MECA etc. and placed 1st 2x with this setup. Anyway this is my baby...
You don't need two amps. The speakers come with crossovers to help protect the tweeters.
14
Perhaps you changed something without mentioning it here? Maybe a loose turn on line? I dunno man...but we'll take it. Hopefully it keeps working. 👍
16
Trixter
Keepin it Simple
Trixter
Colorado Springs, CO
Trixter
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
