Need tips on installing flip down tv
Got a 99 tahoe and where i want to put it there is no bracing just the roof above the headliner. Can i put a thin piece of mdf above the headliner and screw it into that to hold it up or will that make my headliner sag???
use a piece of aluminum to mount it to. you should look to mount it where the dome light would normally be.
well where my dome light is theres a dip in the cieling because i have rear ac ducts on the cieling and also the rear ac controls so i was going to put it directly in front of that where its flat
ill definiely try the aluminum thing tho
just used a piece of 1/2 plywood //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif worked out perfect
jsut watch depending on how big of a board you used that will usually only last a year or two before your headliner starts to sag. Its alway a good idea to ge the board mounted first then the tv to it....
currently I am using 4g wires for my ground and power (1-1.5ft for ground and like 16ft for my power) and no I did not sand the area for the...
106
183
While most Asian and African markets will identify Honda's small hatchback as the Jazz model, most Western regions will know the same model as the...
137
487
MyTrunkSlamz
MyTrunkSlamz
SOUTH SIDE CHI
MyTrunkSlamz
    May 19, 2024
    May 19, 2024
