Need some planning help please!
gettheledout
Here is the full story, I currently have a 1st gen Orion 250 HCCA, bridged at 1 ohm powering my sub. I have an older alpine 4ch powering my door speakers. My sub is a dual VC, so it can be run at either 1 ohm or 4 ohm. My car simply cannot handle the current draw the 250 HCCA pulls, so I need an amp that puts out around 600w RMS with pretty good efficiency. I need to either sell my 250 HCCA, or trade it for an efficient amp. What should I do? Should I try to keep my alpine 4ch, and find a decent amp to run at 1 or 4 ohm, or is there an efficient 5 channel amp that will allow me to run my sub at 1 ohm and my door speakers at a different impedance? Any help is appreciated, or any ideas of trades for my HCCA 250! Thanks!
That's feasible, how many watts do you think the 250 HCCA will make at 4 ohm? Compared to a newer amp making similar watts at 4 ohm, is the loss in efficiency of this older amp worth keeping it?
there will be maybe 100-200W difference in efficiency comparing the HCCA class A/B vs. a newer Class D - 50% vs 80% (approximately). but there is a lot more to it than that, as efficiency varies with impedance load and output.
if you find that you're wanting more output at 4 ohms, you can look at an Alpine MRP-M1000 which makes a CEA rated 600W RMS at 4 ohms
Alpine MRP-M1000 Mono subwoofer amplifier 1,000 watts RMS x 1 at 2 ohms at Crutchfield.com
That is the great thing about Maestro products, they are very thorough. Downside is the price tag.
338
700
455
Very nice to hear you found what you needed to get your audio system/ect. up to your needs. we appreciate the information provided in this thread...
506
gettheledout
gettheledout
Houston, TX
gettheledout
Decebal
    Jun 10, 2024
