Need some advice
Hey man, post pictures of the sub out of the box. We'll be able to tell you what it is. Do you have a multimeter? If so, we can check the coil configuration. As for the amp, provide the model number and we'll tell you what it's actually rated for. Ignore max watts and look at the RMS wattage rating. Given that it is Power Acoustik, you can be sure it isn't putting out that much power but it'll give you an idea. If you really are a newb, we'll need to know everything. What's your electrical like, battery, wire, etc.
Yup , the dsp should have input sections, it may have one for sub? Hu to dsp. Dsp to amps, amps to speakers. Probably help you to draw this all...
501
Honestly, beyond what you need. It will do the trick for sure, but it is excessive. Not a bad thing, just more than you will ever need. No need...
thanks 1aespinoza for advice I decided to not use the blaupunk I got a real nice Pioneer.
607
Man, sounds great - no pun intended! Glad you're happy with those Morels, I think they are special. Not sure why they don't get the local love. I...
36
3K
I'd also recommend that at the very least, you deaden the doors with some sort of mass layer like this Siless Max 120 mil (3mm) 30 sqft Car Sound...
5
889
AmatureSubGuy
AmatureSubGuy
WY
psych0ticnemes1
maylar
    Jun 2, 2024
Doxquzme
    Jun 1, 2024
