need help
  • 2
john_doe_318
i need general info about subs they say db drive speed series sp10.1 but the pic i find wen i Google it isn't my speakers(have 3 tens) and the specs dont seem to match i had the 3 subs bridged to a 1600 watt amp (xterminator 1600.2) and sounded great but the amps ground wire burnt.and now i have a bigger amp kit 4gauge only had a 8 prolly was the problem.and need a amp sugestion and wiring diagram please ps im sorta a noob i have hooked up a few systems
sounds like your subs are dual 4 ohm which if you wired them up to that 2 channel amp you got a 2.67 ohm load [bad] for that amp .that amp needs 4 ohm bridged .so 2 subs will be fine if wired right .as far as specs you'll have to keep looking ,prolly older versions of the same models
Lifelong Pioneer Premier series user here. Switched to the Kenwood eXcelon Reference (XR) DDX9905S and never looked back. Excellent sounding...
9
456
11
840
846
https://youtube.com/@SaabUnleashed?si=-8qdxpYY0yGzrMsL Here you go. This guy does android head unit reviews. His reviews are how I found my...
7
john_doe_318
john_doe_318
bossier city
john_doe_318
1aespinoza
    May 31, 2024
winkychevelle
    May 24, 2024
