Need help with subwoofer and amp wiring
  • 3
Busyb318
CarAudio.com Newbie
I just installed two DS18 genx 12 inch subwoofers and a DS18 candy mini monoblock amp. The subs are dual 4 ohm rated at 450 rms each I have them wired at a 1ohtm load at amp which is rated at 1000 watt rms 1 ohm
or at 450 rms at 4ohm. For two days it has been sounding good . Now it when I barley touch base knob it doesn't sound right . My question is would it hurt to wire them at the 4 ohm load and what will treretbat those Watts on the subs. I don't want to blow them.
Sorry they are dual and wired at 1 ohm
They should be okay at 500 watts a piece. First turn volume down at radio, then with the power off, disconnect the bass knob. Turn on radio and see if distortion is still present. Without the knob, the amp should return to full volume which will be controlled by the radio output.
If clean, your knob or cable will likely be the culprit.
If dirty, connect other subs if possible to test the amp. If other subs sound dirty, the amp is the issue.
If the other subs sound clean, your subs will be the issue. Test each sub individually to see if both messed up.
Also make sure you have 4awg all around. Clean bare metal ground, and snug connections. Good luck.
You have a lot of great points stated here. I like it.. Nothing wrong with a little head room on any amplifier to run at lower gain settings to...
20
3K
That's an older sub, pretty sure it was made by Targa and its the Venom line. I remember seeing them back in the late 90's early 2000's if memory...
11
658
Busyb318
CarAudio.com Newbie
Busyb318
Shreveport, Louisiana
1aespinoza
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
