Need help with a Hi/Low converter
  • 2
colebone
CarAudio.com Newbie
I have a 2016 Impala LT and adding 2 subs and 2 amps in the trunk. Both amps are 1 channel amps but I was told that I need a HI/low converter to hook up to my factory head unit. Problem is all the converters I see are either 2 channel or 4 channel so question is can I make a 2 channel converter work lor so I even need one or can I plug both amps to one?
You can use a 2 channel one and just use RCA Y cables to go from 2 to 4 outputs
Do yourself a favor and get one with a line driver built into it or you amps wont be able to put out the power there are supposed to
Bang for buck the LC line from Audio Control is a good one
The LC1i is $99 and comes with 9 volt pre outs
Lifelong Pioneer Premier series user here. Switched to the Kenwood eXcelon Reference (XR) DDX9905S and never looked back. Excellent sounding...
9
486
11
856
861
https://youtube.com/@SaabUnleashed?si=-8qdxpYY0yGzrMsL Here you go. This guy does android head unit reviews. His reviews are how I found my...
7
colebone
CarAudio.com Newbie
colebone
Charlotte NC
Kickstand
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
