Need help wiring an equalizer
ak49
17
Suprise?
So my buddy gave me and equalizer with subwoofer out because my HU didn't have any, but i don't know how to hook it up. The EQ says on it "Boss Pre-Amplifier Equalizer with Subwoofer" model AVA 1206
Wires are as follows
Black-Ground
Red-12 volt power
Orange-Acc/car st
gray 1-right input +
gray 2-right input -
brown 1-Left input+
brown 2-left input-
Seems pretty straight forward but i dont know how to wire it into my stereo/harnass?
Do i match up the EQ+HU wires such as take both Right impute + Wires, twist them together then solder them to the harnass/plug adapter wire? That is also right input +?
HU \
(Twist/Solder/Wrap)X---------Wiring harnass/plug
_________
EQ /
on the deck there is 1 pair of RCA outs, L and R, on the EQ ther eis rear LR FRont LR sub LR and low-level input LR
so how do i wire thsi thing in lo0l?
Still clueless :/ trying to search info on it, not having any luck? so i just splice into my hu power/remote/ground, and run the rcas from my hu>eq>amp?
use the RCAs from your HU or it might sound like crap. But splice into the hu's power remote and ground is right.
Run the L/R RCA's from the HU into the inputs of the EQ, then the sub outputs on the EQ to your amplifier.
Black is ground, Red goes to the +12v constant (probably yellow on the HU), Orange goes to +12v switched (Red on HU).
Try again on the attachments/pictures. They didn't load. Not exactly sure on the wiring, but you can buy an adapter harness that goes from your...
No not in this situation.PM sent for proper use of the Y splitters for this situation
34
5K
Sure, 600 volts, yep. If you’re trying to launch the subwoofer cones to the moon! And, that’s if they don’t just vaporize first!
34
4K
Is that 1000w max? Don't expect to be able to bridge a 1000w amp at 2 ohms and get 500w x 2ch. I'm pretty sure you can't with that amp, for...
11
515
ak49
ak49
Suprise?
ak49
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
Latest topics
