need help on amp specs! oxygen audio air 2pro m2.5kw and Orion xtr1400 amp plz!!!
  • 1
dbheadrush
Need specs on old school Orion xtr1400 amp, and a oxygen audio air 2pro N2.5kw amp both work fine but I need to know which is more efficient with my 06 cvx 12s d4 wired to 1 ohm( dunno if the Orion is even 1 ohm stable.)
Please help . Also have the older mofo 15s that have a 4" basv/ kapton v.c. if they wud get lower than the cvxs....thanks a bunch guys!!!
I have the CVXs in a 3.5 cu ft itch box tuned to 33 hz with a 4.5" l port
11
876
While we're speculating, why not bump up your volume gain (no pun intended) for just a few dollars more (literally) and go with the 8" versions of...
5
* The fuse at the start of the cable needs to be equal to or greater than the fuse/load at the end of the run. * The cable needs to be capable of...
4
No not in this situation.PM sent for proper use of the Y splitters for this situation
34
5K
dbheadrush
dbheadrush
ft,Myers fl
dbheadrush
maylar
    Jun 2, 2024
Doxquzme
    Jun 1, 2024
