VTLexus 10+ year member
I just installed a 500W mono amplifer to a single 12" subwoofer. i am not getting sound and am having trouble figuring out why.
i have 12V on the power wire, turn on is ~6.5V, and the ground is in place. the amp turns on but nothing out of the sub. i should note the light on the front of the amp flickers slightly when it's on.
i double checked the equipment by putting both in a friends car, and they both work jsut fine. i'm thinkign its either the 6.5V for the turn on, a bad ground, or something wrong with the signal wire tapping. i did try running 12V for the remote turn on straight from the power - still no luck.
i didnt have t-tap connectors (didnt know about them when i started), so i was splicing into the wires and soldering them onto the LOC...slightly mess job.
can anyone help? is there a way to check the signal out of the LOC, or even into the LOC?
