Need Help? Let Me know
Wrapped
First layer of resin
---------- Post added at 09:48 AM ---------- Previous post was at 09:47 AM ----------
Will be installed a little later. I stuffed a little bit of poly fill to help keep vibration down. Keep in mind that I am by no means an expert and wrapping fabric!!! I know there is a bit of overlay behind the speaker.
Second battery added checking charging.
Because there are two amps and fans, I decided to run a relay coming off the remote output of the MS8.
Few pictures of the amps and powered on.
---------- Post added at 09:51 AM ---------- Previous post was at 09:50 AM ----------
Beauty panel
Wires are all organized.
This past weekend, I worked on a good friends jimmy. He completely blew his stock speakers. So I felt like I had to replace them.
Installed
Kenwood head unit
Focal polyglass speakers
metra axxess
Future:
infinity amp
rear speakers
Sub
Lets get started
Before
During
Wiring
I actually switched the tweeter mounting brackets. The left went to the right and right went to the left. This allowed the tweeters to be aimed just a tad of axis.
Today was a simple sub and amp integration into the factory system of a VW R32.
Battery
Fuse block ran and insulated.
Used the 12 volt plug to wake up the LOC
Powered the LOC from the fuse block
Everything ran
Set up
Long story short, the customer contacted me about a year ago to correct what other shops had done. After fixing those issues the customer constantly changed either amps or speakers every month or so. //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
So this is a complete gut and rebuild. Everything is being taken out and re ran or replaced.
The amps will both be on a amp rack above the spare tire. The sub will now be centered in the trunk instead of to the side. Let's begin
Tear down
Found this when I was pulling up the power wire :eek:
They spliced into the power wire for the MS8
The goodies
Today I setup the tweeter pods, and did the first layer of resin.
Made tweeter rings
Glued into place
First time doing the tweeter pods, so I did get some sag. Was not able to stretch it out.
he had that high of equipment and they took a chance on blowing it with such a ****** job?
If you are talking about how the car came to me, you are correct it was shot work. If you are talking about my rebuild, I am not sure why you say that. As I said first time doing the a pillar tweeter pods. The sagging can be corrected.
New speakers installed
Because the door panels have been taken off so many times; I replaced all the panel pins.
Power wire and speaker wire ran
Other pillar wrapped
So today I got a lot done, most of the car is back together. Did get to test the woofers and sub however ran into a few problems including the sub box will not fit because of a seat belt in the way. So I will have to change the location to the left of the trunk and make a new beauty panel.
Working on the sub box.
All the old wires
First layer of bondo
Cut out
All wires organized
655
949
909
bigaudiofanatic
Dynamic Mobile Audio
bigaudiofanatic
Dover DE
FreddyNJ
