Need help deciding which subs to buy Pioneer TS-W304R vs JBL CS1214.
  • 1
heavy49
Hello,
They are in the same price range, and I am planning to buy 2 and put them on a optimal sealed enclosure (according to the manufacturer specs) powering them with a MTX TD1000.1D at 2Ohms which will give arround 300W RMS to each sub. I have already looked at the specs and I cannot make up my mind. I'm looking for SQ, but if it is posibble the one that has the best balance between SPL and SQ.
Here are the links for the specs for each sub.
JBL: http://www.sonicelectronix.com/item_4505…
Pioneer: http://www.crutchfield.com/S-pjm3BkdgZty…
Basically what is keeping me to deside wich one to buy is:
which one will be louder without distoring?
which one has better quality in regards to durability?
how important is xmax? because it seems that the Pioneer sub exeeds the JBL in everithing but xmax.
What do you think, and thank you for your time.
They are good at the boom. Hard pounding lowend but lack at the upper notes. If you have a strong midbass setup they will blend fine. Buuut.. for...
13
Lifelong Pioneer Premier series user here. Switched to the Kenwood eXcelon Reference (XR) DDX9905S and never looked back. Excellent sounding...
9
481
11
853
858
heavy49
heavy49
Calexico, Ca
heavy49
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
