need amp to push sundown sa-8's
  • 5
they will be wired down to 1 ohm, so has to be 1 ohm stable unless it pushes alot of power at 2 ohm other than that not a piece of crap i think that says it all
11
980
While we're speculating, why not bump up your volume gain (no pun intended) for just a few dollars more (literally) and go with the 8" versions of...
5
* The fuse at the start of the cable needs to be equal to or greater than the fuse/load at the end of the run. * The cable needs to be capable of...
4
Thank you for your reply. What if I wire in series for 8 ohm load ? Sorry for my newbie questions, but wouldn't it have better sound quality...
smtroupe
smtroupe
austin, mn
smtroupe
Decebal
    Jun 10, 2024
