need amp for 2 sets of hertz 165
Lots of different amps you can go with... You can do all of the following depending on your budget..
Diamond 500.4
Hertz EP4
Arc KS 300.4
The list goes on.... The Arc would probably be best if you are only running 1 amplifier.
i wouldent mind running 2 amps if it would be better.
price is as low as possable //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
there rated at 125watts, but many people tell me i should run them at 150, so im guessing i would need a amp that dose 150X4 @ 4 ohms or 300x2 @ 2 ohms.
correct me if im wrong, im very noob.
Most recommendations I've seen for these speakers are in excess of 200W RMS, but Hertz told me 150W would be plenty, they said if you need more, your amp is likely crap (that was maybe not the exact wording, but ......). You could opt for an Audison SRx2S, that is 2 channels and the only price I have seen is 300 US a piece. That will give you 2 x 200W RMS at 4 ohms.
11
664
While we're speculating, why not bump up your volume gain (no pun intended) for just a few dollars more (literally) and go with the 8" versions of...
5
968
* The fuse at the start of the cable needs to be equal to or greater than the fuse/load at the end of the run. * The cable needs to be capable of...
4
Thank you for your reply. What if I wire in series for 8 ohm load ? Sorry for my newbie questions, but wouldn't it have better sound quality...
Pyro-IBW
Pyro-IBW
Brooklyn, NY
buggsson
Dylan27
    May 18, 2024
Dylan27
    May 18, 2024
