audiobahnuser18 5,000+ posts
yay for another riceburner on the street. haha nice though man gl with the engine build/swap. i'll race u in my hot rod.
I agree completely, and the ls/vtec motor with proper bolt ons and a PnP head and you are looking at close to 200hp and 175 ft lbs tq...They are very nice motors...Had one in a 91 teg and it was **** fast....Dont swap the b16 block in there. You already have the hard work done now use your rods from the ls in your car already and put the pr3 pistons from the b16 on them and make and ls/vtec. You need to replace the water/oil pump and timing belt when swapping anyway and your old non vtec dizzy isnt gonna work so might as well keep the displacement and make much more power.
That b16 will be a dog in your car since they make no torque and also only make 130-140ish whp but the ls/vtec that you already have will have more displacement and longer stroke with the ls crank and will easily make way more hp.
lol at 200hp= fast.I agree completely, and the ls/vtec motor with proper bolt ons and a PnP head and you are looking at close to 200hp and 175 ft lbs tq...They are very nice motors...Had one in a 91 teg and it was **** fast....
it is on an integra //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.giflol at 200hp= fast.
200 horses at the wheels + 2400 lb car = fast. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.giflol at 200hp= fast.
Lol I'm far from a ricer in most peoples definition of the word. My car is completely stock on the exterior except for the Acura Ls Web wheels I put on and lowering it. I lowered it though for the handling mostly. I'll race you in my hotrod my slow El Caminoyay for another riceburner on the street. haha nice though man gl with the engine build/swap. i'll race u in my hot rod.
stock gs-r usually has little over 120 hp at wheels probably even lesslol at 200hp= fast.
BE CAREFUL WITH THE GOLDEN EAGLE VTEC KIT!!wow that is weird. I was going to post my new plans on here today and someone suggested it. LS/VTEC is what I'm doing now. Poor man's Type R //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Instead of using some money for a b16 tranny I am going to use it for a Golden Eagle Vtec kit.
I'm going to take the water pump, oil pump and JDM P30 Pistons and put those on my ls block. Also gonna upgrade the rods so it'll be able to rev higher.
I'm going to start taking apart the b16 block tonight or tomorrow. Also got these finally
B16 Distributor
And a steel head gasket but leaving it in packaging.
hmm. I know a few friends who did the kit and it's worked but maybe I'll look into that thanksBE CAREFUL WITH THE GOLDEN EAGLE VTEC KIT!!
Ya its easy to install and everything but if i could go back i would just drill my block!
The dowels on my kit didnt fit. so that set me back two weeks for them to send me new ones.
Then it took FOREVER to finally get the oil adaptor to stop leaking!
Went from shop to shop trying to get some advice.!
finally after trial and error!
i torque down the oil adaptor to 80lbs!
it doesnt say this in the kit but i looked up the torque specs on the size of bolt it has on it! used thread locker and used RTV!
and so far it hasnt leaked.
*im just scared to see what happens next time i change my oil!
thanks man!I've only scanned the thread, but I can already say...
lol
To the HS kid building a teg, props. Not many HS kids can say that they're building an engine.
To whothe****ever says Honda motors are junk, you're an idiot. Would I build one for a race car? No. Is it possible? Yes, and they're definitely good engines.
To whoever suggested a 1G DSM, remember, this is a HS kid. DSMs need an adult budget, and an adult driver to make them worthwhile. The 4G63 is a bad ass engine, and DSMs are pretty bad ass cars, but not for a HS kid.
