My 2nd JBL MS-8 goes into protect mode? Any help
  • 3
npcout
PA
This is my 2nd MS-8 that has tanked in less than a year. The first unit went into protect mode 9 months after install. I contacted JBL who said it is not fixable and they replaced it for free. Now after a few months, my new one went into protect mode. Again jbl said it cant be fixed.
SETUP: OEM Headunit to the ms-8, which goes to a 4 channel amp and mono amp.
THE PROBLEM: I turn the car on, and within 5-30 seconds it goes into protect mode. Per jbl who was quick to say, the issue can't be fixed.
Does anyone have any suggestions?
I'm not familiar with ms-8. but check this-
What is your typical DC voltage your vehicle is seeing while on? Are you running externally regulated?
What OS does the MS-8 run on?
Yes Frame is best if second battery is in the rear.There are plenty of bolts and even unused holes in the Frame that can be used for an excellent...
7
Just want a give an update. I ended up trying a capacitor to see if it would work before spending on a battery. The capacitor does work, the...
9
This works. Using a 550Watt RMS Amp. The sub is 600-1800 RMS. No Battery Draining BS. Still sounds clean and low. But DD Amp goes lower and hits...
22
npcout
npcout
PA
shizzzon
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
