I just wondered what watt monoblock amp to buy to power two 12'' svc kicker comp 400w 4ohm subs?
I understand that i need a 2ohm stable monoblock and to wire them in parrallel. But what i need to know is as i'm using the one channel from the amp should I be looking to buy an amp which is 400w rms@2 ohm x1 or because i have two 400w subs should i look for an 800w rms @2ohm x1 amp?
If I was to buy a 400w rms @2ohm amp does the wattage that the amp produce get divided in two because there are two subs or is that the wattage go through both subs because they are wired together through one channel? hope that makes sense.
Basically should i buy an 800w rms monoblock amp @2ohm or a 400w monoblock @2ohm?
