Maybe you can figure it out
couldnt be hooked up backwards or it would never work. In your case, you can do some sort of crazy routine, then everything works properly.
id eq at the db you listen to the most often. our ears dont hear things the same, at different volumes. why tune at 60 dbs, when you listen to 90
10
636
Yeah... check this link out. It shows the power handling of that tweeter. I'd just match the power no matter if you use the crossovers or not...
7
907
Upgraded speakers in my 2023 EX X-line with the 4 speaker stereo, but it definitely needs an amp. The volume of this system is terribly low. My...
11
I had 2 ab 15's in the same size sealed box (4cuft) and it was loud but these sql-15's are on whole different level 🤣
Twist both grounds together. Good call on checking power with a multimeter. I assume you have pulled out and re-inserted the fuses, so as a quick...
m2002brian
m2002brian
Los Angeles, Ca
jstutzman
Doxquzme
    May 12, 2024
Brendon Jenness
    May 11, 2024
