Low Pass Filter
  • 5
mkalsi
7
U.K.
Hi all,
I recently got a subwoofer fitted in my small car. It is a JBL CS1214 in a sealed box, with a JBL A3001 amplifier. The subwoofer is rated at 250W RMS while the amplifier is rated at 300W RMS. I have not upgraded the car speakers.
The problem is, I cannot get a good level of bass and sound quality from the subwoofer. I believe this is because the car speakers are in fact playing full range, while the subwoofer is just adding on top with anywhere from 30-320HZ depending on my LPF setting. I have experimented with different LPF settings, but I am having a hard time hitting the "sweet spot".
I want the extra bass without any holes in the frequency response. What can I do, if anything? Also, there is a bass boost function, which I know boosts 45HZ, but I try not to increase it.
Any help or comment is welcome.
Very interesting replies, thank you. However, I do not wish to spend any more money on this car. It is an old car. I will be getting a new car in the future, where I will transfer the subwoofer setup to. There, I hope to do things properly, depending on the circumstances of the car's exsiting system.
I thought by throwing a sub into the boot will add extra bass, without thinking of the possible sound quality issues. I do have one question. Would the equaliser on a basic head unit change the signal coming out RCA?
I think I'm going to play a 100Hz sine wave and tune the sub so that the crossover doesn't go over. I'm to gradually decrease the filter till I hear the tone come off, then step it back a hair. I don't want any frequencies over 100 to be coming out.
Will post feedback.
U can buy a nice HU and install it in your new car too. So your not wasting any money
I never knew you could get head unit's with crossovers. I thought people get amps +crossovers for these things and keep the head unit flat with RCA to the amps then to the speakers...
*** UPDATE ***
I set the crossover on the sub to 100Hz. Gain is 1/2 on the amp. Sounds decent enough. Packs a punch. Although I have been turning the HU up to it's maximum non-distortion level and working the original speakers for some mid-bass. Ears hurt a little.
There are things I've learnt from all of the replies above. Thank you once again.
n00b basshead signing out
what ^ said. amp gain setting info, test tones are at the very bottom...
520
Thanks a ton for your suggestion to my rather long query, I ll follow it and see how it works out. Thanks again
675
Just for examples sake regarding electrical, I have 1400 watts total between both my amps and my system has no trouble running everything max...
27
Some manufactures actually cut out some of the low end to prevent speaker damage to the factory speakers. I would consider trying one of these for...
mkalsi
mkalsi
U.K.
mkalsi
winkychevelle
    May 24, 2024
1aespinoza
    May 23, 2024
