Line Output Converter on a Grand Prix
  • 3
hypetech
I've got an 02 Grand Prix SE non-BOSE with the factory head unit. I picked up an adjustable LOC today so I can hook up my subs and amp without having to buy a new head unit just yet. I didn't really think about what "adjustable" meant until I got it home, and it turns out it goes from 2-60 Watts, and I'm not sure what it needs to be set at for what I'm using, or even how to set it. There are two knobs (pots) at the bottom for adjusting, but I don't really know how to see what it's set at, or what it should be set at.
Pics of the unit are attached. Any advice?
the two adjust left and right sub. the little knobs are your gain. i have the same one. just mess with your amp and the outline converter to find the best setting. i still dont have mine sounding the best. hope that helps.
Well I have gain on my amp lol. I found something that said to turn them all the way down, turn the stereo volume to 90%, then slowly turn them up to right before distortion, I guess I'll play with it, just didn't know if there was a hard setting. Thanks guys //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
hmm...so I was about to start tearing everything apart and I was making sure I had all my wires, then I realized I hadn't thought about one of them. Where will I hook up the remote turn on wire for the amp? Seems like some LOC have a dedicated 12v wire for it, but not this one.
The correct answer is yes, you want both left and right so you get low end information from both channels. It is very common for recording...
That eq only has one pair of inputs. If you want eq it may be easier to go with the LCQ-1 instead of the lc7i
Most new radios have that feature. Just check that they have 4 RCA outputs. Those are line output. If it only has 2 RCA outputs, make sure they...
hypetech
hypetech
Louisville, KY
hypetech
1aespinoza
    May 31, 2024
winkychevelle
    May 24, 2024
