ladysmanfelpz 10+ year member
So yes i did use the search but im looking for a little more info here from knowledgeable people. So my set up is pioneer 6 1/2s 225w max wired at 2 ohms left and right powered by an alpine t220 and a 10" cvx in ported box wired at 2 ohm powered by alpine mrp450 rated at 400w rms. So my first question is why are some amps 2 ohm stable and some not? Guessing it is just some can handle it and some can't based on how they are made, but with my t220 it is rated at 50w x 2 at 4 ohm and 70w x 2 at 2 ohm. I thought if you cut the ohm load in half, power doubles so it should be 100w x 2 at 2ohm, but is it something in the engineering in the amp that limits it? And also if I am pushing 70w to each channel that means each resistor (speaker) gets then 35w each correct? And so how do you reach peak power of an amp, as the t220 is rated at 250watts peak? I know people say don't look at peak for a build, but its there for a reason. So if I am playing my music at full tilt so its pushing its 70 rms and then a loud section comes in through the signal, if the power is provided it will be able to push a lil more power beyond the rms, so that you don't get distortion and volume drop. Is that a correct understanding of peak power of an amp?
Guess my main question is how can you maximize power output of an amp?
I have less than a foot of 4ga wire running from my capacitor to my amps so they are receiving a ton of current, so hopefully i am allowing them to run as efficiently as possible. Sorry for the long write up and all the questions. Thanks for the help.
