Kicker zx 1000.1 x over freq??
  • 1
redncfootball
4
PA
Im running this zx 1000.1 and a kicker l7 15 it has gain bass boost and xover freq. bass boost is off, gain has been set via dmm and now this x over freq is confusing me. What is the basic range this should be kept at? Also the bass remote that is connectd by basically a telephone wire how do i use this properly? I am using a junk sony xplod deck. It has a subwoofer option 0-10 what does that do and what should i keep that at? I just got the build done and need some answers asap before i put the system to use. Thanks
Yep, that will mark the third iteration of teh X series. i figured that was in the loop as they have been running out of stock on the last...
11
836
Is this a blue or blue/white wire from the Kenwood? The ACC wire is red and although that should turn on the amp, it is not the prefered wiring...
low level when using RCAs so that knob should be pushed out. The crossover turn it all the way right and use the one on the head unit and set it...
5
redncfootball
redncfootball
PA
redncfootball
