SOLD Kicker ZR360
xxxbasshead
Kicker Zr360
does not have the kicker badge or a crossover module included
Details:
* stereo or bridged mono output
* Tri-way capable (Tri-Way crossover required)
* frequency response 10-28,000 Hz
* 90 watts x 2 at 4 ohms
* 360 watts x 1 in bridged mode at 4 ohms (underrated and will run at 2 ohms bridged, not sure about 1 ohm tho)
* 180 watts x 2 at 2 ohms
* MOSFET power supply
* module docking port with 2-way active crossover (80 Hz low-pass, 100 Hz high-pass, 12 dB/octave)
* discrete output transistors
* silent turn-on/off circuitry
* removable endcaps and logo plate
* 18-3/8"W x 3"H x 10-1/16"D
10/10 mech and id say 7/10 cosmetic
175+ship OBO
Will add cash for a good trade.
actual shipping cost thru carrier of buyers choice
ok, screw it. i just found 3 good active cross-overs cleaning my garage......... you interested in the rf? i would need to work something out today, as i fly to work wed just after noon, and it's still installed in my tahoe. lol, i put it in there to see how it sounds and what it puts out................ in like july.
beast amp! my buddy has one powering 4 12s and does mid 140s with this amp! GLWS...very underrated amp. //content.invisioncic.com/y282845/emoticons/thumbsup.gif.3287b36ca96645a13a43aff531f37f02.gif
damnit...... now i got my mind set on the amp.......... there is a possibility i get a bonus at midnight..... otherwise, i won't be able for 2 weeks.....
Mine will take 1 ohm for short periods. They overheat quickly at 1 ohm, and eventually the smoke will come out the box... Should be fine for comps/temp stuff but not for daily. I run mine at 4 ohm on a TC-1000 and it is great, these are clean sounding and are underrated for power. They're great with mids/highs too.
884
xxxbasshead
xxxbasshead
lake forst , ca
xxxbasshead
