kicker l7's
Ive Had taht hifonics amp for some time now, first i had it wired at 2 ohms to a 15" l7 and now i have it moving 2 12" l5s at 1 ohm, and it is a beast poor l5's wanna die of so much wattage, i think it would be nice for 2 12" l7s, but its up to you, i had the 15" l7 in a 4.0 cu @ 40 and now have the 2 l5's at 2.2 each and both set-ups pounded really nice with that amp.
it depends, big 3 and mayby a new optima battery... goto http://www.kicker.com and check out there amps between 1250-2500 and pick which one looks the best to you and fits your price range, if its a little to pricy, you can look at the hifonics bx2006 but u might as well go ahead and get a nice amp now then upgrade later
810
skate21221
skate21221
San Francisco, CA
skate21221
    May 31, 2024
    May 24, 2024
