Kicker L5 Subwoofer Corner Hole
I was wondering if their is any way to repair the corner of my Kicker L5? It has a small hole in the rubber corner.
It sounds fine still, but will it be better with the hole fixed? Or should I just get a new one?
Also, the previous owner applied some kind of super glue or something it looks like on the corners? Or is this from factory?
you'll be able to buy a recone kit for it, that should come with the surround,cone,dustcap and voice coil. but the problem is I don't no were to buy them from for the square woofers
Thats because they arent worth reconing ..to fix the problem u need two things 1)a pair of arms 2) closest garbage can..repair complete //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I've seen whole surrounds held together by duct tape... Give that a shot. Or, even more fun, shoot the kicker with a 12ga. Slugs or bird shot will work, just with the bird shot use an extra heavy turkey choke.
Yep, that will mark the third iteration of teh X series. i figured that was in the loop as they have been running out of stock on the last...
11
897
Is this a blue or blue/white wire from the Kenwood? The ACC wire is red and although that should turn on the amp, it is not the prefered wiring...
low level when using RCAs so that knob should be pushed out. The crossover turn it all the way right and use the one on the head unit and set it...
5
kevinmcc2
kevinmcc2
Pittsburgh
Freeman
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
