Kicker Key180.4
  • 2
It's a good amp, not super-powerful or anything, but the DSP works very well if you follow the instructions correctly in setting it up. I put one in a Toyota Tundra truck, it made a noticeable difference even with the basic factory speakers (non-JBL system). It's not going to win a dB drag race, but that's not what I wanted to accomplish. If you're less concerned with factory EQ and delay correction gains, then you might be better served by getting something more powerful in the same price range. Hope this helps you decide.
Hello, I am looking at installing this Amp with a aftermarket head unit Kenwood dpx-7200dab, my car is a old European Honda Civic 2008 mk8 and I...
Yep, that will mark the third iteration of teh X series. i figured that was in the loop as they have been running out of stock on the last...
11
433
Is this a blue or blue/white wire from the Kenwood? The ACC wire is red and although that should turn on the amp, it is not the prefered wiring...
low level when using RCAs so that knob should be pushed out. The crossover turn it all the way right and use the one on the head unit and set it...
5
928
AnthonyO
Budget Banger Connoisseur
AnthonyO
Minot, North Dakota, United States
Cliff459
Latest topics
