Kicker FDBA distro block
  • 2
wu501
N.Y
S-Series Fused ANL Distribution Block
Can hold 3 ANL type fuses
5 Input, 3 Outputs
1/0 or 4 AWG Input/Outputs
Platinum-plated Solid Brass construction
Smoke colored ABS plastic cover with Kicker Logo
Free USPS priority mail shipping to any of the lower 48 states
5 Input, 3 Outputs
would this take in 4 gauge and put out 3 8's?
smallest wire size would be 4 gauge. This block is made for heavy duty applications and would be way overkill for what you are looking for.
Yep, that will mark the third iteration of teh X series. i figured that was in the loop as they have been running out of stock on the last...
11
763
Is this a blue or blue/white wire from the Kenwood? The ACC wire is red and although that should turn on the amp, it is not the prefered wiring...
low level when using RCAs so that knob should be pushed out. The crossover turn it all the way right and use the one on the head unit and set it...
5
wu501
wu501
N.Y
wu501
winkychevelle
    May 24, 2024
1aespinoza
    May 23, 2024
