Kicker CVR vs CVX
I know they have much more power but just wondering if the bass is a big difference? I have been told i would need to get a high output alternator is this true?
If i go with 2 12'' CVX they are 1500 watts max per sub and 750 rms per sub which would end up being 3000 watts max and 1500 rms. i have looked at the Hifonics Brutus BRZ1700.1D which the subs would be wired to 1 ohm but i don't really understand how that works.
Yep, that will mark the third iteration of teh X series. i figured that was in the loop as they have been running out of stock on the last...
11
872
Is this a blue or blue/white wire from the Kenwood? The ACC wire is red and although that should turn on the amp, it is not the prefered wiring...
low level when using RCAs so that knob should be pushed out. The crossover turn it all the way right and use the one on the head unit and set it...
5
elballz12
elballz12
Decatur, AL
Bettr n' Revrse
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
