kicker 2500 at 1ohm so around 2800-3000 watts ish 4 12's or 2 15's???
  • 5
I wouldn't expect that much power. You'll lose quite a bit after imp rise, voltage drops (if they exist in your system), etc. What subs are you thinking about?
Well if you havn't picked subs why not be safe and run it at what its rated, thsi amp does not make that much more power at 1 ohm.
If you have the room to do 4 ported in correct size box that should be **** loud.
Otherwise the 15" are gonna wang on that much power.
789
Xtremebass5
Xtremebass5
il
skateboardkid
    May 31, 2024
    May 24, 2024
