is this a wiring problem?? see details??
  • 4
Probably a short in one of the speaker wires. Disconnect each one individually and see if any sound comes out of the rest. Or could be you didn't reconnect the factory amp if u have one. Also check input voltages ie: ignition and hot with dmm and see if you reading at least 12volts.
The wiring harness adapter is less than $10 online. It makes everything 10x easier. You just wire your new stereo to the adapter outside of the...
189
Ive doubled up 12 ga many times for sub wiring.. even 14 ga for speaker wiring. Its OFC and it should do great and save you some money since you...
598
My brain hurts just looking at those diagrams. It's late so if anyone sees a problem with either of those, please feel free to chime in!
636
646
555
dellxps
dellxps
calgary,alberta
ecko_0113
