I'd like some advice on speaker choice from the real experts
  • 4
rudedog9d
I drive an '02 Silverado ext. Cab with two 12" Rockford Punch P1 subs in custom enclosed boxes stored under the rear seats. I have been using 6x9's for mids and highs, but then I read some stuff on here, and found out I'm just one of those people that think that craps sounds good. I wondered what was suggested as a solution by you guys for mids/highs. I kind of would like them in removable boxes, As sometimes I like to throw my speakers in my truck bed and chill by the fire.
P.S. I Mostly listen to rock
Thanks!!
-Brodie
Rudedog Racin!!
I don't advocate the use of removable speaker boxes if the goal is good sound. I suggest you get a portable "boombox" player for music by the fire. $200 may get you some decent component speakers, which have separate woofers and tweeters to be installed into the vehicle permanently, but you also need good clean power, sound deadening, possibly new speaker baffles to ensure a solid mount, and this all adds up. You don't have to spend a grand, but the budget is not realistic for big gains.
All of this is assuming you have any idea of the kind of sound you want. You can't figure that out by reading forums. Do you have any good car audio shops nearby where you can listen to some vehicles? Maybe someone on this site could give you a demo.
This is not subjective. Matching the resistance of a given speaker to the amplifier in use is part and parcel of the function of the system. If...
18
To find out what fits, head over to Crutchfield.com. For actual purchase you may want to try CDT.com. They seem to have an everlasting sale. Good...
Yup , the dsp should have input sections, it may have one for sub? Hu to dsp. Dsp to amps, amps to speakers. Probably help you to draw this all...
354
It also lowers the amps efficiency and raises the current draw.
5
465
rudedog9d
rudedog9d
Frewsburg, NY
Justin braaapp
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
