Well I'm gunna be powering two fi btl n2 12s what would be best?The 20.1 is the better amp. The Sundown will make more power though.
What are your subs wired to? If you're wiring below 1 ohm I would go with the 20.1 cause those things are monsters when you drop them below 1...Well I'm gunna be powering two fi btl n2 12s what would be best?
Well they're dual 1s wired to .5 so 1 ohm....What are your subs wired to? If you're wiring below 1 ohm I would go with the 20.1 cause those things are monsters when you drop them below 1...
What are you considering "best?" More power? The Sundown is going to do more power at 1ohm nominal.So what would be best at 1ohm?
Ok well will it be as reliable?What are you considering "best?" More power? The Sundown is going to do more power at 1ohm nominal.
I'll put it this way... I HAD an SAZ 2500. I HAVE an IA 20.1Which would you do? The IA?
Ok cool thx. And I'm not able to afford the amp right now..... Maybe when I can afford it you'll sell me yours! //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gifI'll put it this way... I HAD an SAZ 2500. I HAVE an IA 20.1
If I were choosing, I'd rather have the IA.
P.S. -
IA 20.1 New style - Car Audio Classifieds
