I need help deciding on an Amp
they really only take what your giving them now ,not much more .i'd leave it alone
The thing is that my amp isn't working properly so I need to buy a new one and eventually get new subs too.
I bought a 7" touch screen dvd player last night and I want to have a new amp to install at the same time.
Is this good?
Boss CX1100M Monoblock Power Amp with 1,100 watts!!
Free remote bass knob!
1-Channel mono operation for 1, 2, 3, or 4 subs
1100 Watts Maximum Power @ 2 Ohm
RMS Power Output @ 4 Ohms: 250 Watts x 1-Channel
400 watt RMS @ 2 ohm
2 Ohm stable
THD: 0.01%
Signal-to-Noise Ratio: 100dB
Frequency Response: 9Hz - 50kHz
Built-in Crossover
Strap two amps together for twice the power
Variable subsonic filter
Low-Pass Crossover Frequency: 35Hz - 160Hz
Bass Boost : 0dB - +18dB
Bass Remote
Variable gain control
Power and protection LEDs
Variable lowpass crossover
Dimensions: 10-9/16" L x 11 7/8" W x 2-5/8”H
Weight: 7.1 Lbs
two year warranty
Line And Speaker Level Inputs
Preamp Outputs
Gain Control
anyone else have any opinions on this?: its brand new for about $95 shipped to my door.
2 Ohm stable
THD: 0.01%
Built-in Crossover
Bass Remote
Weight: 7.1 Lbs
two year warranty
Preamp Outputs
Gain Control
I would stay away from the boss amp. If you just search the classifieds on here you can find alot of suitable amps, but just as several others have told you i doubt your jls can take anymore power than you are already giving them.
Lol guys, I said that my JL Amp doesnt work properly so I still need to get a new one and stay below $150.
There is a guy in town that has a never installed kenwood 500 watt 2 channel amp for $100
Is that a good price?
They are good at the boom. Hard pounding lowend but lack at the upper notes. If you have a strong midbass setup they will blend fine. Buuut.. for...
13
685
961
928
Jordan W
Jordan W
Saskatchewan, Canada
Jordan W
