i need a amp for a 7000 watt rms speaker
About the only 7K amp that is half reliable is the Stetsom 7K. All the Chinese/Korean ones are time bombs. That being said something tells me OP has no idea what sort of electrical system an amp like that will require to operate properly and if he gets his hands on a 7K amp will blow something up within 12 hours.
that sub will cook with 7kw daily, even on music. And I'm not hatin on the sub either just the fact that even a 4" coil will only take so much power even with awesome cooling.
OP do youself a favor and go for a solid amp ~4kw, DD, Stetsom, Sundown... Less power needed, and ytou won't be heart broken because you thermaled the sub
11
849
While we're speculating, why not bump up your volume gain (no pun intended) for just a few dollars more (literally) and go with the 8" versions of...
5
* The fuse at the start of the cable needs to be equal to or greater than the fuse/load at the end of the run. * The cable needs to be capable of...
4
Thank you for your reply. What if I wire in series for 8 ohm load ? Sorry for my newbie questions, but wouldn't it have better sound quality...
redrum757
redrum757
virginia beach,va
Tallc
1aespinoza
    May 31, 2024
winkychevelle
    May 24, 2024
