how to run 3 batteries? (1 under the hood 2 in the back)
  • 4
Hey fellow car audio people,I already have a stinger SPV44 660 amp battery and I'll be buying another one soon but I have no clue on how to wire the 2 together. I'll basically be running my normal battery under the hood and these 2 in the back. Obviously I'm just getting into the bigger systems so,any help on this would be awesome! (current system is 2 massive audio hippo 8s + massive audio N3 amp ) (COMING SOON system will be 4 hippo 8s + 2x massive audio N3 amps )
n3 amp RMS 1400watt
Hippo 8" 500 watts RMS
thanks for the help trying to get this set up before November for import face off.
check the float voltages of all 3 fully charged but unwired just in case before you put them together. you're running the same battery so it should be simple just make sure you fuse like adulbrich said.
if it turns out your current battery is low id go with a different brand just for cost savings without diminishing quality
Just for examples sake regarding electrical, I have 1400 watts total between both my amps and my system has no trouble running everything max...
27
You should run all exact matching subwoofers in one singular enclosure and 1 amp or matching amps for the best listening experience for the space...
11
I am out of the car audio world the more my ears age. However, I am very much still a hobbyist in the electrical field. With much of my current...
15
Running wattage below RMS won't hurt anything. What the speakers get is the same thing as running an amp with higher wattage and then turning the...
14
@Dappster360
@Dappster360
Baton Rouge,La
adulbrich
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
