Head unit or not?
  • 1
VisChaos
Is it better to utilize a HU eq/x-over to the amps via the 3 sets (F/R/subs) RCAs, or should I get separate units for each task?
I also have an audio control ESP-3.. I want SQ out of a SPL set-up.
I have a JVC exad KD-AVX2 DVD HU, front RCA to ESP-3, out to amp for center, then through on ESP-3 to a Memphis eqp4 then to front, rear and subs.
Should I ditch the ESP-3 and the eq and just run all from the HU?
How about a second eq.. 1 for the front from HU front RCA and the second from the rear HU RCA and run the subs from that eq as well?
At the moment I have two Alpine 4ch amps and
2 kenwood 1000 watt amps..
2 kenwood excellon 12"
Alpine 6.5 co-ax for center
Clarion 3.5 co-ax, in the dash factory hole, from HU
Alpine type-s components in the factory front doors
Kenwood 6.5 in a custom hole in the rear doors
Custom 5.25 components in the rear windows
All in an 05 Scion xB.
It's plenty loud (in the low 150's db), but I feal I could cut the amount of speakers and electronics.. In an attempt to bump up the SQ...
6
489
One or two, they are still subwoofer outs and are mono summed signals from both left and right. Even the 2 RCA subwoofer pre-outs on the 2nd one...
758
There are a couple of options. You can use a marine bt unit. They come in the size of a hockey puck and can mount anywhere. This is the marine unit.
802
There are bluetooth amplifiers. You can just use your phone or an I Pod as the music source and not touch the radio.
Avoid jvc 480bhs hard to see the display in the daytime even with the brightness all the way up also not as easy getting to the audio menu like...
5
VisChaos
VisChaos
Noblesville, IN
VisChaos
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
