How GOOD will this sub x amp go together? & how will it sound?
Those two are very good products. Two things I have to say though.... 1. Make sure you actually want this kind of equipment in your car. If you havent... go out and listen to peoples systems. Make sure the constant BOOM BOOM BOOM is something you want. Most people are surprised at how loud something like a type X can get (type r's are still very loud). and 2. Shop your options. When I just not looked up the specs for the Type X I came across it for $250
I like the amp. But i'd go Fi Q for woofer. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Though the Type-X (I consider it SQL) is not shabby.
That's what sub/amp controls are for //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif you can always turn it down more. But you can't always turn it up more. Just my .02
And to most people here, 1000rms and a single Type-X would be considered low output. It's all relative, ya know?
the the cadence, audioque, or mach 5 are much better options imho easily the mach 5 and cadence will get louder as they are much beefier subs
icon is also a much better sub
the hdc3 is obviously gonna be louder since it can handle double the power the type x can
for a daily setup, i'm taking the type x if i had to choose between the 2.
118
737
Using a Y RCA to split signal from amp to amp to give both amps the signal they need from the HU and subs in different /separate enclosures tuned...
810
Hahaha his brother got some from a friend. American bass amp and some alpine s 12in subs. From a buddy of his now Eastons chomping at the bit...
838
Hello all. Used to come on these forum quite a bit. I used to compete in IASCA MECA etc. and placed 1st 2x with this setup. Anyway this is my baby...
Radrick Davis
Radrick Davis
Goodlettesville, Tennessee
Radrick Davis
