How do you tell if you damaged a driver?
  • 5
you'll hear it, if you push on the cone and it scratches its bad
small drivers like that will not handle any clipping or overpowering for long, if at all
As wew lad said, and do the simple battery test too which is free.
My question is how do you know the smell came from a 6.5" speaker? Not the sub or amp.
I would not press the cone, mids don't have high gap tolerance so any pressure off dead center will cause you to hear some type of rubbing noise. Pull the mid(s) out put them on a multimeter see what they are reading at and play it free air on mid power level and see if you can hear any rubbing noise.
Check out Sonic Electronix as well. They have some great deals usually and excellent Customer Service also. I like to buy my HUs /Head Units from...
6
589
Ive never seen this amplifier before. Can you take a pick of the back? Interesting amplifier.
8
Without a photo this is the best I could come up with, note the "physical port length" is at 22.5" and if you measured down the portwall to get...
I had two of the Xtreme 12's and they were dual 4ohm. They read at like 3.5ohm per voice coil which is common.
9
deweys2
deweys2
Carolina
OKAY
Decebal
    Jun 10, 2024
Decebal
    Jun 10, 2024
