SOLD HO POWERMASTER Alternator 200 amps
CerwinVega_Fan
Coolest Member
4,474
Dallas,TX
LARGE CASE High ouput Powermaster Alternator.
Brand new in BOX!
Made for GM cars. (cs144)
Does 130 amps at idle
Does 211 amps highway
Asking $300 for this.
From a quick search looks like the same setup just on the other side of the motor. The only issue you may run into other then needing a longer belt would be using washers to space it out or grinding down the mounts to set it back farther. Not sure if it would be 100% bolt on as it may be off just a tad on the line up. It will fit though.
Hello I also have a question I want to buy 160ah lto, i.e. 4 banks but I have a stock alternator of 140 a and a maximum load of 14.9 do you think...
Okay cool bc I'm thinking about getting 5k amp and just wasn't sure if that battery would do but I appreciate all the help
18
I don't have one...but I check my voltage with a dmm once a week or so
12
You just found your own solution. Move the DSP elsewhere. The RCA is triple protected but not the RCA plugs. I do not know if there is a mesh or...
CerwinVega_Fan
Coolest Member
CerwinVega_Fan
Dallas,TX
ejschultz
Doxquzme
    Jun 15, 2024
Doxquzme
    Jun 15, 2024
