SOLD Hifonics BXI1610D mono subwoofer amp
nismos14
Jersey
1. Product:
Hifonics BXI1610d
2. Specs:
# Brutus BXI Single-Channel Monoblock Super-D Class Car Amplifier
# RMS Power Rating:
* 4 ohms: 550 watts x 1 chan.
* 2 ohms: 1100 watts x 1 chan.
* 1 ohm: 1600 watts x 1 chan.
# MOSFET Power supply
# Super D-Class amplifier relies on a super-speed enhanced chip-set to produce higher current capacities and more precise digital to analog conversions
# Wired remote bass level control included
# Power and Protection LED indicators
# Built-in system diagnostics offer protection of DC, Speaker short, terminal, and overload
# Tuned Bass EQ (0-10 dB bass boost at 45 Hz)
# Dampening factor: >250
# Single-channel monoblock channel operation
# 1-Ohm stable
# Phase shift: 0-180 degrees
# Preamp RCA outputs
# Input level control: 0.04V - 18V
# Balanced line input for MX accessories and line drivers
# Heavy duty aluminum alloy heatsink for extreme heat dissipation
# RCA level inputs
# Screw terminals
# Variable low-pass filter (35-250 Hz, 24 dB/octave)
# Subsonic Filter (15-35 Hz at 24 dB)
# Frequency response: 35-250 Hz
# Dimensions: 14-1/4"L x 9-1/2"W x 2-1/2"H
# 4-gauge power and ground wiring is required for installation. Contact us for information regarding a discount on select amplifier kits when purchased together with this amplifier.
3. Description/Condition:
When it comes to class D monoblock amplifiers, Brutus amplifiers are truly the king of D class. Brutus BXI amps are considered some of the best amplifiers in the world and the new Super-D Class Brutus amplifiers reinforce that. The D-Class digital chip-set technology produces extremely efficient, low temperature, and a high amplification system resulting in a smooth digital to analog conversion with low distortion. The amplifiers stable at 4, 2, and 1 Ohm(s). All in all, that means that the amp will produce more output with less stress on the car's battery and charging system.
4. Price: :
$235 shipped
5. Pictures:
Yep, at the amplifiers. I get the same 14.7 volt reading when they cutoff too.
12
Pull it and test it at the battery post. Simple Power up test to verify if it powers up fine out of protect mode. if it does then Id be checking...
I have a Gemeni VII, Heucules VII, Pluto VII, and a Vulcan VII left out of a massive slew of VII and VIII series. They still work Excellent...
5
3K
  • Locked
COMPLETED Hifonics Plato III
Yes, they are painted. The cover is very easy to take off and repaint to whatever color of choice to match the install.
  • Locked
NVX MVPA1 Best tiny amp Installed a bunch, but have one pushing a sealed 12 @ 2ohm in my daily beater Can bump it all day long and barely gets...
4
791
nismos14
nismos14
Jersey
nismos14
